How to check for bad COPs with multimeter
evolucion311
236
Hey guys,
Can anyone explain how one would check to see if a COP is bad? I have an 02 GT that is hesitating and stumbling at low RPMs under high load in low gears but not WOT.
Specifically, what range of resistance or voltage is normal for a healthy COP, unhealthy?
When mine went out it was for good. Threw a code and missed entire rpm range. But to answer the question you should attach an ohmmeter between the coil primary terminal (prongs inside connector ). It should read 0.55 ohms. Connect between secondaries (inside boot and connector). Should read 5.5K ohms.
Update:
I tested my COPs with a multimeter. Testing at the two pin connectors resulted in a 0.9-1.2ohm resistance. Testing impedance between a pin and the bottom of the COP resulted in a 5300ohm resistance. Testing of the COP spring itself resulted in a 4ohm impedance.
The result was the same for all COPs.
The middle two COPs on the passenger side were a bit difficult to obtain a reading for when measuring the pin-spark plug impedance. The reading danced around wildly until I was able to get the usual 5300ohm reading. I suspect these two may have some problem to them but I cannot say for sure. Again, its just a guess not founded on anything solid.
I pulled the spark plugs and they look normal with a slight grey/brown color to them.
Is there another test I can perform to try and find the source of this low RPM miss?
Keep in mind that the ohmmeter test of a COP only tests one aspect of it. The winding resistance, primary and secondary, can be tested with the ohmmeter. However, the insulation quality cannot. That is, there is insulation internal to the COP separating these windings. If the insulation has been punched through or is otherwise weak but still somewhat intact, you may get a normal resistance reading on an ohmmeter but the insulation breaks down at a few kilovolts, it can limit the spark energy available.
If you suspect a bad COP and have misfire codes for a given cylinder, check the resistance with the ohmmeter as you've done. If it checks out, swap the COP with another cylinder and see if the misfire follows the COP or stays with the cylinder. Replace any COP(s) that have a misfire following them around...
i had the same problem on my 02, I pulled the driver side valve cover off and my timing chain was loose, the tensioner arms were wore down to nothing, changed them out and the car is alive again, also i had replaced the COP's, for that price you can get new timing set. good luck
There is no way to check if a COP is bad without a COP tester. When I had a bad COP, it OHM'ed out correct. I bought 1 COP at Autozone and swapped it out 1 by 1 until I found the bad one. It never threw any codes either.
i did exactly the same thing and my faulty coil tested within spec also, so the resistance test is pretty useless if you ask me :nonono:
I tried the swapping route, and after about a week of swapping, and not getting anywhere, I gave up and did what I should have done from the beginning. Take it to ford, and have them run a load test on the COPS. 10 minutes at the dealer, $75 later, and I knew exactly which 4 were weak. Replaced those, put new boots and springs on the others, and life was good again.
