How to check for Ignition module/coil problems?
NewBlueGT
1,409
San Luis Obispo
So far this hard start issue has gotten nowhere fast, last time I posted the only suggestion was regarding the Fuel pressue regulator.
Well after talking to a couple shop owners, they have informed me that most fuel parts failures are not related to temperature, meaning my car would start like crap always, not just when warmed up.
Does this make sense?
So eliminated the theory of FPR issues, I was told that electrical problems are more sensitive to heat, and may be the culpret to my hard starts.
I was told to check the Ignotion module or coil, which might be producing weak spark and ultimitely hard starts.
So, does anyone agree with this advice? How do I best check these parts? I was told to let the car run, then after shutdown feel the coil to see if it is warmer than it should be.
Any help would be appreciated guys, without a working car I can not afford to stay in college.
more info on the old issue would help.
heat is hard on ignitions. the TFI's are famous for going south when hot.
one can take it in for a bench test. i would have them repeatedly test it, since the issue *sounds* like it is intermittant.
if a weak spark is found, testing the coil or replacing it is not a bad idea.
are there any codes? the CEL does not have to be on to have codes stored.
good luck.
Cranks OK, but No Start Checklist for Fuel Injected Mustangs
1.) Remove push on connector from starter solenoid and turn ignition switch on. Place car in neutral or Park and set emergency brake. Remove coil wire from distributor & and hold 3/8” away from engine block. Jumper the screw to the big bolt on the starter solenoid that has the battery wire connected to it. You should get a nice fat blue spark.
A.) MSD or Crane ignition box if present.
B.) Coil
C.) TFI module
D.) PIP sensor in distributor
E.) ECC relay next to computer - look for 12 volts at the fuel injector red wires
F.) Fuse links in wiring harness - look for 12 volts at the fuel injector red wires
G.) Ignition switch - look for 12 volts at the ignition coil red/lt green wire.
H.) Computer
2.) Spark at coil wire, pull #1 plug wire off at the spark plug and check to see spark. No spark, possible failed items in order of their probability:
B.) Distributor cap
C.) Rotor
D.) Spark Plug wires
Two reasons:
Clue – listen for the fuel pump to prime when you first turn the ignition switch on. It should run for 5-20 seconds and shut off. To trick the fuel pump into running, find the ECC test connector and jump the connector in the lower RH corner to ground. See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html for a description of the test connector. If the relay & inertia switch are OK, you will have power to the pump. Check fuel pressure – remove the cap from the schrader valve behind the alternator and depress the core. Fuel should squirt out, catch it in a rag. Beware of fire hazard when you do this. In pinch you can use a tire pressure gauge to measure the fuel pressure. It may not be completely accurate, but you will have some clue as to how much pressure you have.
No fuel pressure, possible failed items in order of their probability:
C.) Clogged fuel filter
D.) Failed fuel pump
E.) Blown fuse link in wiring harness. Look for 12 volts at the Orange/Lt Blue wire on the fuel pump relay
F.) Fuel pressure regulator failed. Remove vacuum line from regulator and inspect for fuel escaping while pump is running.
Fuel pressure OK, the injectors are not firing.
A.) A Noid light available from Autozone, is one way to test the injector wiring.
B.) I like to use an old injector with compressed air applied to the injector where the fuel rail would normally connect. I hook the whole thing up, apply compressed air to the injector and stick it in a paper cup of soapy water. When the engine cranks with the ignition switch on, if the injector fires, it makes bubbles. Cheap if you have the stuff laying around, and works good too.
a.) Pull an injector wire connector off and look for 12 volts on the red wire when the ignition switch is on.
b.) No power, then look for problems with the 10 pin connecter (salt & pepper shakers at the rear of the upper manifold).
c.) No power and the 10 pin connections are good: look for broken wiring between the orange/black wire on the ECC relay and the red wire for the black 10 pin connector.
4.) Spark & fuel pressure OK.
A.) Failed IAB (no airflow to start engine). Press the throttle ¼ way down and try to start the car.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
In your case, I would mark the distributor base and the engine block with an alignment mark so the you can restore the settings. Then with the engine warm & not starting, loosen the bolt holding the distributor. Turn the ignition switch to the run position. Then remove the coil wire & hold it 3/8" from the block. Twist the distributor back and forth, you should see the coil wire sparking. Observe the quality of the spark, it should be fat & blue. Align the distributor with the mark you made on the engine block and tighten the hold down bolt when you are done. This will restore your original ignition timing if you were careful with the marks.
