IronMedic said:take the upper manifold off and prime the system off and on with your keys in the acc position about 5 times. just have someone watch
jerry beach said:You need to locate where the gas smell is coming from. If they are leaking into the combustion chambers, then you should get a puff of black smoke out of the pipes when you start it up. Run the engine till warm and shut it off, then start it up after only a few min. If you let it sit too long, the fuel will evaporate.
Pull the spark plugs and see if they are wet. Smell them. This is a good way to tell.
Your timing may be off, or your idle may be too high. Did it just start doing this one day, or was there something that led up to it? Have you worked on anything recently?
BlackFox5.0 said:Acording to my Haynes book, it says causes for "Dieseling" are:
1: Idle speed set to high
2: Ignition timing incorrectly adjusted
3: Thermo-controlled air cleaner heat valve no operating properly
5: Excessive engine operating temp. Probable causes of this are malfunctioning thermostat, clogged radiator, or faulty water pump.
Hope that helps![]()
TK_05 said:yea i read the book... im not even sure what, 3: Thermo-controlled air cleaner heat valve no operating properly, is...
Is it possible there is carbon built up in your combustion chambers? Are you getting any pinging at high rpms or under heavy loads.jerry beach said:Your car doesnt have one. Is it possible that you motor is running a little hot? I would move the timing first and see if that makes a difference. You did set the timing with the spout out right? Just checkingIs it possible there is carbon built up in your combustion chambers? Are you getting any pinging at high rpms or under heavy loads.
jerry beach said:I am guessing that your car is an auto. Shut it off in gear. This should stop the run-on. I had one running on because of a vacuum leak. That is something you could check for. Go up a grab a vacuum guage if you dont have one and test away. If you car is not heavily modded, this will tell you alot.
TK_05 said:yea but is there anyway to fix that? i dont really want to shut it off in gear all the time...
I really didnt mean for that to be a cure, just a temp fix till you figure out whats up. So have you pulled codes? Pay attention to the EGR valve, block it off and see if things get better. Like I said start checking for vacuum leaks, visual test first...I am running out of ideas fast, but you will find it.TK_05 said:ill try the DMM on the injector thingy... i dont think its the plugs i think its something electrical because if i start it up.. key off then key right after it will stay running...
