billison I like tinted tail 15 Year Member Feb 27, 2006 2,607 1,094 184 stl Jun 14, 2006 #1 Jun 14, 2006 #1 Ok, i'm changing my timing chain cover gasket due to a leak, and i wanted to check to make sure the chain is still good and that the timing was still good "i've had back firing problems while decelerating" what should i look for?:SNSign:
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 33 129 Jun 14, 2006 #2 Jun 14, 2006 #2 Cam/valvetrain timing and ignition timing are two separate elements - I'm sure you knew that, but some seem to confuse the two. You can check the chain spec (it's listed in the manual) while the TC is off. Here's some info on setting ignition timing. Good luck.
