  • 1994 - 1995 Specific Tech
How to: Cleaning guide, Brackets / Pullies, Rust Removal
  • Thread starter Thread starter Yellow302
  • Start date Start date Jun 18, 2008
Yellow302
789
NJ
Jun 18, 2008
  • Jun 18, 2008
Does anyone have any tips / pointers on this subject... i need to get rid off all the rust on my parts before I can prime/paint them.
Right now i feel like i'm spinning my tires and getting no where.
T
turbogt
723
Montana
Jun 18, 2008
  • Jun 18, 2008
blast cabinet is the only efficient way to do things..
Chythar
Recently finished repairing my rear
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Jun 18, 2008
  • Jun 18, 2008
Depends on the parts and the rust. Any rust where gaskets have to sit will have to be cleaned carefully and the surfaces checked properly or the gasket won't seal right. If you have light rust you can sand with wet/dry sandpaper. If the rust is pretty thick you can use a wire brush. There is a gel you can buy in most auto stores near the body repair section. It's a gel that converts rust into a primer-like substance. Worked pretty well for me.
Yellow302
789
NJ
Jun 18, 2008
  • Jun 18, 2008
i got my new engine from the junk yard wich the block and heads have rust which i need to get off before i can paint.
I don't want to buy new head gaskets from pulling the heads. if i can paint/squirt some stuff on there that sounds perfect.
http://www.youtube.com/watch?v=KJeXwsl87us&mode=related&search=
When searching i found this link to the video... i have my oil pan full of rust... i need to do this to it.
The jell sounds good for the block and heads... what was the name of it?
Chythar
20+ Year Stangneter
Aug 26, 2004
2,374
140
113
Foothill Ranch, CA
Jun 18, 2008
  • Jun 18, 2008
*watches video*
Damn! That's a good idea. I don't remember the name of the gel, I'll have to see if I have some still at home. There are also rattle can sprays that will also convert the rust into a primer-like coating. You'll still need to use a wire brush to get off all the loose rust.
D
Paint removal on machined gasket surfaces.
  • Ddyer2868
  • Feb 16, 2026
1965 - 1973 Classic Mustangs -General/Talk- Feb 23, 2026
ctandc
C
SOLD 1986 Mercury Capri 5.0 5-speed
  • blackmerc
  • Jul 29, 2026
Fox Body Mustangs For Sale (1979-93) Aug 24, 2026
General karthief
coil pack bracket
  • SteveG94GT
  • Apr 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Apr 11, 2026
SteveG94GT
Cleaning up Aluminum
  • limp
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 13, 2026
KRUISR
J
can you use the heads off a H O 302 to put on a regular 302 engine
  • Jan H
  • Feb 25, 2026
  • Other Auto Tech
Other Auto Tech May 17, 2026
nickyb
