How to drain fuel tank
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
I'm getting ready to fire my car up. It hasn't run in 6 years. I've gone through it and changed pretty much every fluid and cleaned up everything i can think of prior to cranking. I've even replaced the fuel lines tank to engine with brand new stuff.
I have yet to prime the pump. Reason being the fuel in the tank is 6 years old. I added stabil, but not sure how it would act if i tried to start it.
I want to drain the tank (half a tank) and add fresh gas. So how do i do it? I beleive the filler neck is an anti-siphon design??? Or is it not??
Or should i fill the tank with fresh gas, mix it up well and then try to start it? :shrug:
There may be a better way, but one of the first things that comes to my mind is taking your fuel line loose, and having a helper turn the key for the pump to prime and let the pump pump it all out into your catch container.
I've done that before on another vehicle, but not on a Mustang, so there may be a better way.
The thing is, the pump will only prime for a second and then stop. I'd have to keep cycling the key or jump out something to continuously run the pump. I also don't have a battery for the car yet....so no power
I do have a 190 LPH pump to install, so i was thinking of just biting the bullet, dropping the tank now and changine out the fuel pump and siphoning the tank while I was there.
I really didn't want to do that now though. I just want the old gas out.
There should be a fuel pump test switch around or in the same connector you do the code checking self test. If you jumper the +12V at this connector to the fuel pump test line, then you will turn on the pump continuously until you pull the jumper wire.
I did this on a Grand National about 1 year ago. I just connected a hose to the shrader fitting on the fuel rail then jumpered the pump test wire. Drained all of the fuel from the tank in a couple minutes. Real ez, just have enough fuel cells to remove the fuel or transfer the fuel into another vehicle once it is full.
Those $2 siphon pumps work faster than you think. The fuel pump self test jumper is a good idea too.
My buddy got an el-cheapo external fuel pump, a length of hose, and some wire with alligator clips... and we drained the tank in his truck like that.
Ya, take a hose and siphon it, wont sucking it out work?
You dont have to get every drop out, just most of it, I started my car up after a while too and I didnt even worry about the old fuel. It DID run like **** though, so I went to the store and put in new gas and no prob .
As far as priming the engine, its good to do, but I didnt really prime it. Just started the car up.
I would not want to run all the crap in the bottom of the tank through the pump unless you're going to replace it anyhow (and if so, just drop the tank and manually dump the gas).
drop the tank..isnt that hard...then u can tottaly drain it and por 15 under the spare tire well... just get a buddy to help drop it using a jack also
That's why i don't want to drop the tank now. I'm out of POR-15. So i'll need to order some up as well as a new tank filler gasket (they always rip) and i was thinking of using POR-15 gas tank sealant inside the tank.
So that's why i just want to drain the fuel now. I have a HUGE project planned just for the fuel tank area.
So you can siphon gas from these cars? I was under the impression they had an anti-siphon filler neck.
I'll do that then.
This... Jump the fuel pump at the test connector while having a line unhooked and going into a bucket. But IIRC, you don't jumper to 12 v.
On edit, courtesy of JIRichker.
