how to fix hydrolocked motor.
natestang5.0
60
This may be a little off topic but one of my buddies was driving one of those argos with 8 tires ,all wheel drive. I think it has a 17 horse power motor in it. He sank it and he was so drunk he forgot to turn it off before he sucked water in the motor. Does anyone know a quick fix or do i need to disassemble the entire motor. Thank you for your help.
Yep. what he said.. make sure you take all of the plugs out at once.. or he could still bend a rod. we had to do it to a friends caddy... shot water from one end of the garage to the other
I see hydrolocked motors all the time - usually it bends the rods - if you are lucky all you need to do is pull the plugs, drain all the fluids, spray penetrating fluid in the cylinders, put in cheap fresh oil, run it a bit and then drain it back out til it is all out.
He's probably looking at bent (if not broken) rods like stated above. bsedwebt70-5.0's method is probably the best way to go. I hydrolocked my brother in laws prelude (broke 2 rods, bent another, and bent the crank) and my jeep (broke 2 rods and bent the camshaft with a broken rod).
