not sure about a '96, but my 2k I had to use about 2' of extentions, a swivel and a shallow 1/2" socket. Run the extentions out toward the front of the car, between the exhaust manifold and the motor mount hump. You will have to snake the end between a few hoses to get it to line up. I had to lay under the car, feet to the frontand my hand guideing the socket, while movint the extensions with the other. once it was hooked all it took was a good turn with a long ratchet, or break-over bar. I hope that helps.
