here's a little update.since i installed these connectors,the passanger side muffler would rattle against the rear connector bolts.
i put the bolts in the wrong way
and was too lazy to get back under there and turn them around
the nut is too thick,that's why the muffler would rattle against it,as you can see.
here's where it rubbed against the muffler.
i took the bolt's out and turned them around.first i checked them for any abnormal wear.they looked good as you can see.
i checked the hole's to see if they were elongated,they were not.the bolt still fit snug.
reinstalled them with the head of the bolts on the inside of the frame rail.
drove home after and no rattle
