Alright, I just ordered my Ford Racing Flywheel(I got a CAT, but found out it was a POS..money lost there
) & my SPEC Stage II Clutch. How hard is it to install? This is how I figure it goes:
Put the clutch onthe flywheel facing the right way towards the motor, then put the flexplate over the clutch and slide the plate over the studs on the flyhweel while aligning it with the pilot tool. Next, bolt the flew plate down, and put the Throwout bearing on....is this all? This is all I know, so if im leaving stuff out, Please help.
Also, the flex plate doesnt need to go on any special way right? As long as it goes on the studs & it matches the bolt holes correct? Same for the clutch? Just make sure I have the motor side of the clutch facing the right way? IVE NEVER done a clutch job, but are decent enough to service my own motor.
