How to know if you have gears installed
Guero
2,148
How do you find out if you have aftermarket gears already? I cruise at 2200 at 80 mph. I was thinking about that because i bought it not to long ago and just thought about it right now.
You will turn the wheel one revolution. The Driveshaft will turn like 2 3/4 times (or 3, 3.5, 3 3/4, just over 4 etc) turns in that one wheel revolution. However many times the DS turns is your rear end ratio.
So if the DS turns ~2.75 times for one wheel revolution, that means you have 2.73 rear gears. You are using the DS and wheel as an extension of the ring and pinion to display the ratio (the ratio is: Driveshaft revolutions to wheel revolutions).
Good luck.
Trying to compare your mph & rpm to other members values could very well be pretty much useless due to the fact that our tachs can be really far off.
Like JT said, an accurate and simple method is to chalk mark the bottom of a tire and the bottom of the drive shaft and count the turns. That way, you will know for sure.
btw, if your wondering about how many rpm's you will be turning at various speeds with various ratios here is some info for you ... enjoy
http://www.allfordmustangs.com/Detailed/608.shtml
Grady
