I'm working on putting new window trim on some new doors i've got but they're power and not on the car....what part of the harness do i put power to so i can lower the windows? Also is it safe to just use a car battery for the power source?
Do you have your door panel removed? You can just loosen the three motor bolts and release the motor from the regulator gear and slide the window up and down by hand. Or just remove the motor all together, that is how I would do it.
a power and a ground from a battery just plug them straight into the plug for the motor if it does not go down swap them around.... simple and you dont have to take anything apart
