How to lower engine temp.
DO use two separate switches for the low and high speed fan since low requires 12 volts and high takes ground.
And dont run both at once - it will fry the motor.
Good luck.
FIRST: Welcome to Stangnet!!!!
You didnt list your mods, but if you have a lot done, OR youre planning on it really soon, esp aluminum heads, I would suck it up and shell out the cash for a Fluidyne radiator. THere are some "fan-rigging" things you can do now, but in the long-run, the Fluidyne will help. You can always get a tuning device if you do more mods that will program the fan to come on earlier. Im not a fan of rigging electric stuff unless you KNOW what you are doing.
Good Luck
RC
yeah it runs hot but its not hurting anything its how it came from the factory. I wouldnt go hacking into the fan wiring either, i was real close a few times, but i never did, and now im glad cause i have my tweecer and i can now adjust it to whatever i went instead of having to flip a switch.
