How to remove column?
  • Thread starter Thread starter tillmanspeed
  • Start date Start date Jun 11, 2006
tillmanspeed
24
  • Jun 11, 2006
I am trying to fix my bezel around my gauges and all. There is a screw on one side which I have off. I need to get the 4 way flasher off to get the rest of it to come off. Does anyone know how that thing attatches?
Any help is appreciated.
Chris
PuterAmI
513
Madison, Alabama
Jun 12, 2006
  • Jun 12, 2006
Always helps just a WEE bit to know what year Mustang one wants help with.
tillmanspeed
24
  • Jun 12, 2006
1990 Mustang GT
It looks like 4 way screws off or something? It's hard to tell.
Thanks
Chris
PuterAmI
513
Madison, Alabama
Jun 12, 2006
  • Jun 12, 2006
Is "4-way flasher" the emergency flasher? Isn't it a part of the multi-function switch? (turn signals, headlight flash)
If so, just take the multi-function switch off. Two screws, if I remember correctly.
tillmanspeed
24
  • Jun 14, 2006
There is a bolt on one side of the "collar" so I can pull the whole assembly half way off. On the other side the 4 way flasher button is holding the rest of the bezel on. It is a button all by itself for the 4 way flashers. If i can figure out how to get that off, the rest of the collar will come off. Any ideas?
THANKS
PuterAmI
513
Madison, Alabama
Jun 14, 2006
  • Jun 14, 2006
I am perplexed. I had no idea Ford changed so much from the 89 to the 90.
On my 89, the 4-way flasher (emergency flasher) is a switch on the right side of my gauge pod right above the switch for my convertible top. Did they move this to the steering wheel column in 90?
The only "button" I have on the column is the white one at the bottom that allows my ignition switch to come back to the "LOCK" position so that I may take out my keys.
The "collar" is a round piece that goes around the back of the steering wheel (I have tilt). It just snaps apart on one side and comes right off.
The two upper/lower trim pieces that hide the column are held on by three screws. The white "button" goes through this.
There is one more lower trim piece that attaches to the bottom of the gauge pod that is held on by two screws.
Good luck.
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
R
Interior and Upholstery How to remove seatbelt torx screw
  • Riley Barth
  • Jul 6, 2026
Fox 5.0 Mustang Tech Jul 13, 2026
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
R
Interior and Upholstery Interior roof adhesive removal HELP
  • Riley Barth
  • Jun 22, 2026
Fox 5.0 Mustang Tech Jun 23, 2026
Riley Barth
R
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
