How to Remove Cruise control?
if you take your plastic drivers side inner fender off you will see a black rubber boot covering where the cable goes into behind the tire or behind the GT side badge on your fender.. if you remove the boot and take the top two bolts out if the plastic box, it will pull appart and you will then see where you can undo the cable and pull it out.
So that black ball in the innder fender comes out too? Also Those Two rubber lines coming from the black plastic box with the subber boot on it, do those come out also??? One rubber line i notice goes to like a T connecter with other black rubber hoses and the other thicker one goes through the firewall and under the dash, So my question is what do i do to the black rubber hoses
Reactions: Rose Red 94 Vert
