  • SN95 4.6L Mustang Tech
How to remove fog lights?
  • Thread starter Thread starter scupking
  • Start date Start date Aug 22, 2008
scupking
1,186
Enfield, CT
Aug 22, 2008
  • Aug 22, 2008
I just put new headlights on and my old stock foged out fogs look bad. How do I take them out?
G
GettinThere
553
Central Texas
Aug 22, 2008
  • Aug 22, 2008
Damn, it's been awhile, I hope I remember right. First, you don't need to remove the bumper. Others will recommend it, I'm just saying you don't have to. There are three screws holding the fog light housing to the bumper. Two are easy to remove, as you can see them. One is hidden, remove it by feel.
speed545
458
Montreal, canada
Aug 23, 2008
  • Aug 23, 2008
Lot easier if you remove the bumper but if not, 1 under the bumper cover and 2 you can reach from inside the bumper cover. But like mention before, you ll have to get it by feel.
Also, they are torx screw so easy to get a hold on them without seeing
southfillyboy
38
  • Aug 23, 2008
Actually an easier way it to take out the phillips screw out. It is at the front of the light and then you will see that the light swivels up and down. it should then pop out with a little force.
Black_02_GT
Mississippi
Aug 23, 2008
  • Aug 23, 2008
i tried this and wouldn't really recommend it... too much risk of popping one of the pegs off the light... i would say just take the bumper cover off and undo the 3 screws holding it in.. easy stuff.
san~man
O-G
A little grass shack on a big lava rock
Aug 23, 2008
  • Aug 23, 2008
I tried to install my clear ones w/o removing the bumper and chewed up my knuckles in the process.
The bumper comes off with relative ease. I would recommend you do it this way instead, and your knuckles will thank you later.
Dr Jay
134
Canada
Aug 24, 2008
  • Aug 24, 2008
I changed mine with the bumper on in the driveway. I had no issues, just had to work on the ground.
southfillyboy
38
  • Aug 24, 2008
I had no choice. One of the screws got stripped but I found that they went in and out very easy.
Superhereaux
chicks make me feel inadequate
538
South Texas
Aug 24, 2008
  • Aug 24, 2008
There should be three 20 or 25 torx screws holding each one in.
Removing the bumper seems like overkill, like dropping the oil pan to change the oil, but i could be wrong
G
GettinThere
553
Central Texas
Aug 25, 2008
#10
  • Aug 25, 2008
  • #10
10-4, yeah I got it backwards, one visible and two hidden. Removing them wasn't too hard.
FoxRod87
243
Carolina
Aug 25, 2008
#11
  • Aug 25, 2008
  • #11
Just jack the car up in the air and remove the 3 screws and you will be fine.
2010 V6 Sees differently than GT?
  • 6t9Mach1
  • Mar 31, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Apr 1, 2026
6t9Mach1
Electrical Headlight Harness Route
  • dan50
  • May 3, 2026
Fox 5.0 Mustang Tech May 3, 2026
dan50
O
Forscan experts? No fog lights!
  • optionizerSS
  • Aug 26, 2025
  • 2005 - 2009 Specific Tech
2K
2005 - 2009 Specific Tech Feb 19, 2026
optionizerSS
O
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
