How to remove rear end assembly from my stang?
support the axle housing with jackstands near the housing itself....remove the UCA bolts from the rear-end housing...remove the shock bolt from the rear-end mount, remove the LCA bolt from the rear-end mount, remove the calipers, remove quad shocks, place jack under the housing, remove jack stands, lower rear-end, should come right out.
