how to run straight up carb?
jnobles06
85
Clovis,NM
i have a 95 v6 that was converted to a 351w carb. the wiring in it is all f@#! up and i want to rip everything out and rewire it carb with no computer how do i accomplish that? what do i need? any info will help. thanks.
iskwezm said:
get rid of all the wiring.For a carb all you need is wiring for guages,ignition, and that pretty much it
I just finished my swap from 4cyl F.I. to 302 Carb. I just eliminated all the wiring and ran just what was needed, A hot ignition wire to the starter solenoid, bypassed my neutral safety switch and installed a mechanical Cap and rotor (made it much easier, will put electronic one on sometime). It is pretty easy though, just takes some wiring knowledge.
what all wiring is needed, ex how does the ingnition work and what all kinds of stuff like that do in need? should i get like a msd 6al, msd coil, and dist? what does the electronic choke on a carb hook up to and will all my blinkers, and lights work with out the computer and stuff? would my stock guages work or will in need aftermarket ones? thanks.
My car was converted to carb. Believe me, it's pretty hard to rip out a piece of wiring you actually need when going from efi to carb setup. I went underneath my dash and pretty much everything underneath there was feeding from other locations and was no longer needed. I ripped out like 20 different wires and still have more to do.
