If it looks like a bigger version of a Cleveland, then it's either a 351M or a 400. As to which, it's damn near impossible to tell the two apart, the 351M is just a destroked 400. If the original valve covers are present and haven't been swapped the displacement is on the left cover info sticker. I've used a dipstick inserted into a spark plug hole to tell the stroke, but came up with 3 inches on a 400, due to the angles involved as the piston moved down the bore, when rotating the crank by hand. Could also be a 460, if the thermostat housing bolts to the intake, and not the block.
