how to test coil packs on91 2.3
oo7thenova
342
CALIFORNIA
well guys , my car shut down while cruising on the freeway the other day.
it cranks but it doens't start or fire up. theres fuel but no spark. i changed the ICM, but no go.
whats the best way to check if the coil packs are bad?
i want to check for power at the coil connector? or resistance?
thanks guys
it isnt too hard, you have to remove all the belts, and the crank pulley. As long as you dont remove the timing belt you dont have to align anything. If you Do remove the timing belt you will have to set the cam timing. Which is just basically lining up the marks. Its not a difficult Job.
Dr.
