How to tighten strut
  • Thread starter Thread starter loudexhaust
  • Start date Start date Aug 15, 2007
L
loudexhaust
99
  • Aug 15, 2007
I'm replacing the struts on my 91. When I try t tighten the rod, the piston just spins. How do I get this thing tight?
Wallzy
128
Orlando, FL
Aug 15, 2007
  • Aug 15, 2007
Use an impact gun.
87'GTstang
1,025
  • Aug 15, 2007
Wallzy said:
Use an impact gun.
Ditto. You need the instantaneous torque of something like an impact gun.
ninety15.0
1,336
  • Aug 15, 2007
Well what i did was take the largest flat head screw driver you have and a set of vice grips. Put the flat head in the slot on the top of the strut piston. Then take the vice grips and grab the shaft of the screwdriver down really low. Then just take a box end wrench and tighten the strut piston nut while using the vicegrips and screwdriver to hold the piston steady. Worked for me when i did my caster camber plates in my apartment parking lot without air tools. An impact gun works wonderfully!! But sometimes all you have is hand tools...good luck man
ShortThrow50
923
Pa
Aug 15, 2007
  • Aug 15, 2007
I bought a 75 dollar cordless impact wrench from pep boys that has 200 pounds of torque. I Bought it after wrestling for an hour trying to do what you trying to do. Brought it home, charged it up for about 10 minutes, and BLAMMM! Blew that *****er right off. Works great putting the new ones on too
HISSIN50
34
129
Aug 15, 2007
  • Aug 15, 2007
Ninety15.0's method is how I've been doing them for awhile. If you have a set of prybars that are like a long flat-head screwdriver with a bend near the tip, they fit the slot nicely and provide good leverage.
Good luck.
larrendeuce
649
Southern NJ
Aug 15, 2007
  • Aug 15, 2007
There is a tool called a drag link socket, looks kinda like a flat head but its thicker and made just for this job. Should be able to get one from snap on, matco, or even try craftsman.
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
3K
Fox 5.0 Mustang Tech Apr 11, 2026
Engine Code 41 again
  • Creomod
  • Jul 7, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
Mcmahst
Suspension Shock install ?
  • DemonGT
  • Feb 10, 2025
Fox 5.0 Mustang Tech Feb 10, 2025
91AOD5.0LX
