How to tighten strut
Well what i did was take the largest flat head screw driver you have and a set of vice grips. Put the flat head in the slot on the top of the strut piston. Then take the vice grips and grab the shaft of the screwdriver down really low. Then just take a box end wrench and tighten the strut piston nut while using the vicegrips and screwdriver to hold the piston steady. Worked for me when i did my caster camber plates in my apartment parking lot without air tools. An impact gun works wonderfully!! But sometimes all you have is hand tools...good luck man
I bought a 75 dollar cordless impact wrench from pep boys that has 200 pounds of torque. I Bought it after wrestling for an hour trying to do what you trying to do. Brought it home, charged it up for about 10 minutes, and BLAMMM! Blew that *****er right off. Works great putting the new ones on too
Ninety15.0's method is how I've been doing them for awhile. If you have a set of prybars that are like a long flat-head screwdriver with a bend near the tip, they fit the slot nicely and provide good leverage.
Good luck.
