Ok, it has teh 12v power wire, and the 12v going to it when cranking for the smaller wire( drops down to like 10/11 or whatever when its cranking but there is power going through it).
I found this in the instructions via summits website
CHECKING FOR SPARK
If triggering the ignition with the White wire:
1. Make sure the ignition switch is in the "Off"
position.
2. Remove the coil wire from the distributor cap
and set the terminal approximately 1/2" from
ground.
3. Disconnect the MSD White wire from the
distributor's points or ignition amplifier.
4. Turn the ignition to the On position. Do not crank the engine.
5. Tap the White wire to ground several times. Each time you pull the wire from ground, a
spark should jump from the coil wire to ground. If spark is present, the ignition is working
properly. If there is no spark skip to step 6 below:
I dont get step two, would i just disconnect the dizzycap to coil wire and then take the white one coming from the MSD and tap it?
