How to use 28oz stroker on 89 stang?
Bigstang1
415
Massachusettes
I have been looking on ebay for a cheaper stoker kit and i see alot of them that say they will work with 5.0 roller blocks, but as i rread it it says that they are balence for 28ox imbalence. Is it as simple as using a different flywheel and dampner to change it voer to 28oz? thanks
When you buy a stroker kit, you should have it balanced regardless. Some of the cheaper kits will cost you more in the end because it takes more time to balance them correctly. So by saving that $50 or so on the crank , you end up spending twice that to get it balanced correctly. Not the case with every kit, but it does happen.
Need the flywheel and balancer like N8 said. You could also give them your clutch assembly when you do the balancing.
