95Mustang302
- Mar 30, 2005
- 302
- 0
- 16
stang22 said:That's not a high-speed orbital, right?
Tim
TheDamned said:well mine is 3200rpm i think
stang22 said:That's a lot of RPM, but remember just because it's capable of 3200RPM doesn't mean you have to use 3200RPM. Burning through the clear coat would suck. I have always buffed between 800-1100 rpm.
Tim
TheDamned said:ummm, okay, its pretty hard to control the RPMs tough it just a button, no throtlle.
Thanks for the head up tough.
There's a huge difference between yours and the DeWalt. Good luck. TheDamned said:Oh it's 2600rpm...
stang22 said:The internals are probably turning at 2600rpm, but the pad itself is probably turning much, much slower than that. You won't burn your paint with the one you have.![]()
Tim
Ok, if you don't know how to use the buffer definately do not attempt to use it on your car.
stang22 said:The DeWalt is what most body shops use after they wet sand a car to buff it out. As long as you don't use anything abrasive with the buffer/polisher that you own, you will be ok. That DeWalt buffer spins between 0-2500rpm, add a little bit of pressure and something abrasive and you can really mess your paint up. The Autotopia site has a bunch of good information on it, check it out when you get a chance. I certainly don't want to confuse you anymore, but your buffer is for the typical wax/polish. Most people use that buffer because it is easier than applying and removing wax/polish by hand. I know that's what I use mine for. Sorry to confuse you, just trying to help out.
Tim
Zero Signal said:I use the PorterCable 7424. I got that and all the stuff (pads etc) from http://www.properautocare.com/porcabpolac.html
Unless you really know what you'e doing, don't get a speed buffer. You will leave more swirl marks than you had before if you don't do it right and you';; probably burn through at the corners. This buffer with a stiff pad will eat through paint if you really want it to. I like it becuase it's small and can get into every nitch.
I use each pad with each compound. The NXT Tech wax is good stuff for the money. I only used the swirl mark remover with the stiff pad on my hood when I bought it already painted black from the junkyard. It's awsome stuff! The yellow pad to the right is the stiff, the middle is medium and grey pad is soft.
Here is the hood that sat in a junkyard for who knows how long. It was NASTY when I got it. I wish I had before/aft, I just have after
http://www.u.arizona.edu/~jtennant/Pics/MyPhotos/poor_car/Junkyard Hood/
Zero Signal said:
