How to Wire Aftermarket Gauge Lights
1989MustangLX
118
Canada
I've got the gauge pod installed in the car, and the gauges have their little sensors run through the firewall. Now they need an engine to measure. How can I hook them up so that the lighting dims with the stock gauges? My wiring diagrams didn't help me at all. Thanks.
The dead side of fuse 13 will work as a place to tap into (that is the dimmer fuse). Or grab a dimmed light (like the HVAC lighting, radio illumination, etc).
Good luck.
I never used the dimmer switch (the fuse is very close to the switch anyhow, so I used it instead). Sorry. :)
Good luck.
Nope. The fuse is in series after the dimmer. If you put your test light on the fuse you will see what I mean. When you run the dimmer down, the test light dims too. Cool!
I tap in on the dead side of the fuse and then put the smallest fuse I can find (often a 1 or 3 amp fuse I have on hand) in series on the new wire going to the gauges. That way if yournew gauge lighting shorts for some reason, hopefully you will blow the in-series fuse and not fuse 13 (so you can still see the stock gauges while driving home). Cool?
Good luck.
I also like using that fuse as well. I don't use extra fuses (just the way I prefer), but I do make sure I use the cold side of the fuse (as mentioned above) so that fuse works for the gauge lights as well.
