I posted this a few months ago but didnt get much help.
When i drive my car there is this grinding sound in the rear end when I am driving. Its hard to describe it but I am going to say its like a howl, like its echoing somewhere. It sounds like it may be in the wheelwell or the rear axle. I put it on a lift and rotated the tires and didnt hear anything. I also turned both rear rotors, didnt fix the problem. I fear its inside the axle. It is not a constant grind but sounds like something is hitting one certain spot during each revolution. Sound speeds up (a little) at higher speeds. Has anyone had this problem or know what it may be? I will be replacing gears shortly, should this problem be taken care of with that? When i get back I will have the mechanic check it out and hopefully he can tell me what it is.
Thanks for all your help
