I got a quote on a 351c 4v with quench head: $2500 for-
block fully prepped
stock 4ma crank polished or just turned
H beam rods
forged,wiseco/brc pistone
total seal rings
clevite H bearings
svo roller timing chain
solid cam from isky or comp
solid lifters
rotating assembly balanced
new performance damper
fel pro rear main seal
cam degreed
kevko oil pan and pickup
melling oil pump AHV style
front cover
4V quench chambered heads milled for studs
one piece SS valves
isky valve springs
comp guide plates
arp studs
crane retainers and keepers
felpro head gaskets
comp push rods
roller rockers
Everything but the intake and carb, Intake would add 200 to the price and 300 for shipping. This isn't a rebuild im buying the block and heads off them also. DO you think I could get my block and heads built like this for much cheaper? I also have to consider if I buy the complete engine off them I could always sell my parts I was going to use for my own build and make some $$$ back. Considering I have headers, timing set, clean 4v CC heads, intake, carb.... unfortunaly some of these parts were for my 2v buildup so wouldn;t work on my 4v build up. What would U guys do. Right now im looking at a complete engine for 3k including shipping from oil pan to intake, should make about 450HP.
Thanks,
Jim
block fully prepped
H beam rods
total seal rings
clevite H bearings
solid lifters
cam degreed
front cover
one piece SS valves
isky valve springs
comp guide plates
arp studs
felpro head gaskets
comp push rods
roller rockers
Thanks,
Jim
