Ok heres another theory for ya, go ahead and put a track heat intake or an edel rpm or rpmII or hell even just a gt 40 setup on there and sure youll gain hp and on some even some tq however the main reason for it is the stock manifold is restrictive to begin with, and you either shorten runner length or lengthening it, so why does a better flowing intake give power? better flow to each cylinder. Now supply the best flowing intakes on a stock setup such as a box intake a victor intake or anything that flows more than the heads can handle and all you have is a car that will barely run, (this is also an experience thing) now put a power adder on this thing and it works like a dream??? Why you are now forcing the air in, unless the engine can suck in the amount or air introduced without a adder IE better heads or better cam then what are you doing with the extra air? Where is it going to go? it has to go somewhere so it backs off causing turbulence or better a tumble effect. That will not help things at all. Now all this aside if you really want the best answeres and even more in depth explanations call Ed Curtis, or Call any good cam or induction specialists and pick thier brain for a while, thats what I did and still had to back it up by doing it,(i'm extremely stubborn) and unfortunately they were right and I was wrong. Now that my combo consists of much better flowing componets I now can use the extra air flow, I have had to upgrade many other things in the process fuel, Fuel pressure, timing, spark etc. And surprising enough my stock 24# are still supplying ample fuel. Now with the turbo setup in its future I will have to go back to the drawing board and start picking more brains. Ohh and an intake makes power by distributing the air more evenly among the cylinders so more air can be introduced thus making the power you speak of.
