I posted this in 5.0L Tech but since you guys are used to flat tappet tech i thought i would ask you. Ok according to desk top dyno on my current combo if all i was to do is swao from my 274 XE flat tappet cam to a Etreme Hyd Roller 282 i would see a 20 hp jump at 4000 rpm and a 47 hp jump by 5500rpm torque would also be up with 49 more ft/lbs at 6000 rpm. Now im a little scepticle. can these really be right? the roller cam actually lifts the intake valve less then the flat tappet cam. i know there is more duration but nearly 50 hp from a cam swap? is this possible?
