HPX Ignition
  • Thread starter Thread starter ozstang65
  • Start date Start date Jan 26, 2004
ozstang65
313
Queensland, Australia
Jan 26, 2004
  • Jan 26, 2004
Just doing a bit of research the other day and came across this website:
http://www.electromotive-inc.com/products/hpx.html
I was just wondering if anyone here has used this multi-coil, crank-fired setup and has any comments?
SandSprite
332
L.A., CA
Jan 27, 2004
  • Jan 27, 2004
my cousin has one one his Pinto 2.0 powered sandrail. Seems to work great, but may be overkill for most.
Red Barchetta
761
Behind the Orange Curtain
Jan 27, 2004
  • Jan 27, 2004
My friend uses this setup in a Hemi powered Sprite. It works in conjunction with the fuel injection system. He has the older DOS version of the software, which makes tuning a little more of a hassle. The new version of the software runs on Windows and looks a lot more user friendly. All in all, the ignition works very well. They just need to put the car on a dyno to fully dial in the fuel injection & ignition.
ozstang65
313
Jan 27, 2004
  • Jan 27, 2004
Red Barchetta said:
My friend uses this setup in a Hemi powered Sprite. It works in conjunction with the fuel injection system. ...
I was thinking along the lines of doing that also, just with central fuel injection, not multipoint. Do you know how the ignition module interacts with the EFI?
Red Barchetta
761
Jan 27, 2004
  • Jan 27, 2004
They're using the TEC-2 system which is the complete engine management package. It's essentially the predecessor to the TEC-3 system. I don't know what the main difference is between the two, other than there's some more functionality with the TEC-3 and that it's Windows based.
As far as how they interact, it's all dependent on the fuel injection control module. My friend also has the Electromotive ignition in a Chebby powered 240Z. He's using an old version of the Accel fuel injection system which takes its signal from the ignition, however, it is unable to advance or retard the timing.
The new Accel setup, as well as the FAST setup are a couple you might want to check out as they both should work with the Electromotive ignition.
If you don't want to do much fabrication with the intake manifold, you may even want to try talking to Edelbrock and see if their Pro-Flo EFI System is compatible with the Electromotive ignition.
ozstang65
313
Jan 28, 2004
  • Jan 28, 2004
Thanks for that, I'll check them out. I'm keen to add a modern touch to the old 302. I'm kind of used to a motor that you get in, turn the key and off it goes! (as well as not draining the bank balance with excess fuel usage)
SandSprite
332
L.A., CA
Jan 28, 2004
  • Jan 28, 2004
Red Barchetta, that wouldn't happen to be Darius's 240Z, would it?
Red Barchetta
761
Jan 28, 2004
  • Jan 28, 2004
No, not Daruis, though I am somewhat familiar with his car. I don't know if he's using the Electromotive ignition with his setup.
  • dan50
  • Jul 18, 2026
dan50
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
D
Engine 85 GT Backfires through Carb
  • DienstXIV
  • Oct 3, 2025
Fox 5.0 Mustang Tech Oct 7, 2025
85GTStangGuy
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
R
2003 Roush Stage 1
  • Ritual
  • Aug 2, 2025
  • What is it Worth?!?!?
What is it Worth?!?!? Aug 3, 2025
