HUGE Problem!!! Need help.
  • Thread starter Thread starter 91stangy
  • Start date Start date Apr 30, 2007
9
91stangy
116
  • Apr 30, 2007
I bought myself some AFR 165 heads, assembled the motor and was putting the valve covers back on and a bolt snapped in the head. We then drilled the bolt and started pulling it out with an extractor and would you believe that it (the extractor) also snapped inside the bolt. So I had gotten no luck with shattering or removing the small piece of extractor because I believe some dark forces, like wizards and gnomes, just don't want me beating Camaros all day long. And apparently this extractor is made out of Wolverine’s bones from X Men.
So here are my questions:
1. Does anyone have an idea on how to remove this evil from my cylinder head (remember it is a valve cover bolt).
2. If I can not get it out, I was thinking of using a silicon called "The Right Stuff" which I have heard is amazing along with the gasket, while tightening the 5 existing bolts down evenly. Will I have a major leak problem or will I be ok missing one valve cover bolt?
Now for an idea which one it is, looking at the driver's side valve cover, the bolt that snapped is farthest right and in the back, closest to the intake manifold.
Please help, I've had the most unfortunate events happen on the day I was going to put the engine back into my car. Thank you all for your help in advance.
I
irish
168
Florida
Apr 30, 2007
  • Apr 30, 2007
Oh that really sucks, been there a time or two, take head off and take it to a machine shop and have them drill it and rethread it, ez outs are made of VERY hard metal. Buy better bolts for valve covers next time, no major torque there they should not snap...sorry for your luck, mine was a water pump bolt(new) with a torque wrench.....
Mr Grim
58
  • Apr 30, 2007
if you can get the car to a machine shop, they should be able to burn it out while the head is still on the block. I've been there a time or two myself.
Flavadave4
1,044
21
49
Utica, NY
Apr 30, 2007
  • Apr 30, 2007
Dude this sucks, I'd prolly do like those guys said and take it to the machine shop.....you don't want to muck up your new heads!
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Apr 30, 2007
  • Apr 30, 2007
is there anychance enough is out of the hole that you could weld a small bolt or nut to it. The heat from tac welding the nut onto the broken bolt usally frees them up so that you can easily turn it out. Always worked for me.
whtpny
338
Spokane WA.
May 1, 2007
  • May 1, 2007
Send both the heads to me and I will take care of the problem. I will even pay for shipping. J/K , that is no problem for a machine shop. I wouldn't mess with it anymore myself on those spendy heads. Good luck.
Aryan15
236
CA
May 1, 2007
  • May 1, 2007
I did the exact same thing with a water pump bolt. I managed to chip out the extractor leftovers with the tip of a tap(or something else very hard) and drill out the body of the bolt without violating any of the threads. I have yet to have a good experience with extractors IMO.
P
Pete3983
10
  • May 2, 2007
I had a similiar problem when I replaced my heads. The head bolt broke off in the block. I didn't know what to do except possibly a new block, but instead a buddy recommended using a heli coil which is just like re-threading it. So I drilled out the bolt put the coil in and never had a problem again, everyone told me that the block was going to spit that bolt right out with the coil but that was 10,000 miles again and there isn't even any pressure near there.
Mustang78
486
Aberdeen, WA
May 2, 2007
  • May 2, 2007
if you can get the extractor out(did you drill all the way through the bolt? if so maybe you can pound it through..), a little propane torch will surely do the trick, aluminum expands at a faster rate than steel, so theoretically when you heat that area up with a propane torch the aluminum head will expand before the bolt and it should come out MUCH easier
~Mark~
MAC'n89Blckstng
1,012
NJ
May 3, 2007
#10
  • May 3, 2007
  • #10
How tight were you crankin the valve cover bolts? They only really need to be hand tight.
ninety15.0
1,336
#11
  • May 3, 2007
  • #11
I was wondering the same thing....no need to wrench on those. Get some heat on it and see what you can do. If all else fails bring it to a machine shop.
Cooling Jacket Pitting Idea's?
  • BoostedRed89gt
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Mustang5L5
Forced Induction Bypass valve backwards?
  • Dontknowchit
  • Jun 25, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
JD1964
M
Need help!
  • Masonevans726
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 17, 2025
Masonevans726
M
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
L
Engine Need help diagnosing 2 dead cylinders
  • lvgnmz
  • Feb 13, 2025
Fox 5.0 Mustang Tech Feb 13, 2025
Mustang5L5
