Humidity causing bad shifts
cybergomer
The problem I've got is the trans basically dropping out of gear at will. Sometimes it will jump back and forth a few times and other times its almost like it drops into neutral. This problem only seems to rear its ugly head in high humidity.
I kinda suspect its engine related, because when I put more of a strain on the engine by running the A/C, the problem gets worse.
Any ideas on what could be causing this to happen?
