  • 2005 - 2009 Specific Tech
Hurst or Steeda
  • Thread starter Thread starter ilovemynintendo
  • Start date Start date Jan 17, 2009
  • 3
First Prev 3 of 3
anthony05gt
1,262
Maryland
Jan 25, 2009
#41
  • Jan 25, 2009
  • #41
When I had the Steeda Triax in my stang I'd be taching above 6000 rpm's and shoot for 3rd gear and hit the brick wall. Or going from 3rd to 4th once in a while it would try to hit 2nd. I have over a million miles stick shift driving experience and this crap was unacceptable. I was actually kind of scared to speed shift this car. With the MGW shifter I have never missed a gear. I can plant the gas to the sheet metal and shoot for any gear and 3rd gear is the easiest now. You don't even have to think about it...just push the shifter forward without looking for 3rd at all and it goes right in smoothly.
Steel Horse
Altoona, IA
Jan 25, 2009
#42
  • Jan 25, 2009
  • #42
How many turns do you have yours set at? I put mine on late this fall and it felt pretty notchy. Only got a week and a half to drive it before it went to storage. Mine is set at 8 turns. I've heard they get smoother after a month or 2 of driving. Just curious what other people have set theirs at.
Trail of Dead
43
England
Jan 26, 2009
#43
  • Jan 26, 2009
  • #43
MGW all the way man, just look at one....B-E-E-F! Apocalypse strong, those things are made from shards of Thor's hammer. I had one on my old '99 GT and it was king. As another poster said on here..."see the light".
STANGmole
245
Portland, OR
Jan 26, 2009
#44
  • Jan 26, 2009
  • #44
well, I'm not anthony05gt...but I can tell you I've got mine at (I "think" if memory serves me right) 6 turns and it's plenty notchy. It also seems to have gotten worse over time but I think that it's due to the transmission because of the weather getting colder and not the shifter. When the car's warm it shifts OK but if it's cold out it can be difficult to get it into reverse and any of the first 3 gears are rough (it takes the synchros more time to mesh). I had problems with my last two 5spd non-Tremec Mustangs too when it came to reverse and cold shifting and both were fixed by synthetic ATF so that might be an upgrade I'll do in the near future.
I was actually thinking of turning mine in a couple of turns to make it less notchy. Even at its longest throw setting I bet it would shift better than the stock shifter due to it being more precise and that return spring for the 3/4 shifts.
L
Lennyvb
57
Centerport, NY
Jan 26, 2009
#45
  • Jan 26, 2009
  • #45
I have mine at 5 and the shaft as high as it will go (bottom of shaft flush with the bottom of the shifter block) and it's not notchy. I thought of going to six but instead lowered the shaft which may have accomplished the same thing. It's stiffer but no problem getting into gear even in the cold. You may want to bring the shaft up and see if the additional leverage makes it easier. When I bought mine I spoke with George who told me a lot of guys turn it out to the max and push the shaft down to the bottom which makes the shifting stiffer or notchy. He recommended bringing the shaft higher and letting the leverage work for you.
Steel Horse
Altoona, IA
Jan 26, 2009
#46
  • Jan 26, 2009
  • #46
Thanks guys. I've been on the fence about adjusting it since I have had a limited amount of seat time since installing it. Either way it is light years ahead of stock.
STANGmole
245
Portland, OR
Jan 27, 2009
#47
  • Jan 27, 2009
  • #47
Thanks!! I never even thought to check that out...you might have saved me a trip under the car.
L
Lennyvb
57
Centerport, NY
Jan 27, 2009
#48
  • Jan 27, 2009
  • #48
I hate to touch the threaded portion of the shift linkage - paranoid about stripping the thread. Let me know how lowering the shaft works for you.
anthony05gt
1,262
Maryland
Jan 27, 2009
#49
  • Jan 27, 2009
  • #49
I have mine at 8 turns and the shaft is almost as low as it will go...maybe 1/4'' from the bottom. I plan on changing mine to just a couple of turns and raising the shaft about 1/4''. I want a bit longer throw and a bit more leverage even though it feels good. I'm used to a longer throw like all of the old school cars had. Our cars look kind of silly with too tall of a shifter coming up out of the console so I'm thinking 1/4'' more won't drive me nuts looking at it. Some knobs stand up higher than others when threaded in so you have to take that into account too. The stock style knobs thread way down deep and sit very low. I just couldn't be happier with this shifter, especially the way you can tweak all this stuff including being able to move it from side to side (rotational) within the console.
Anybody with a notchy feel while using an MGW shifter probably has the noise coming from the transmission. Try Royal Purple Syncromax.
NastyStang113
1,567
Florida
Jan 27, 2009
#50
  • Jan 27, 2009
  • #50
I had to trim my shaft so it wouldn't bottom out ...
anthony05gt
1,262
Maryland
Jan 28, 2009
#51
  • Jan 28, 2009
  • #51
Sounds like that must have hurt!
NastyStang113
1,567
Florida
Jan 28, 2009
#52
  • Jan 28, 2009
  • #52
The MGW shafts are very solid and hard so it took a big chop saw to make a clean cut.
  • 3
First Prev 3 of 3
Subframe connector question
  • B0udreaux
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 5, 2026
rednotch
Hurst comp 5sp Shifter springs Help
  • R82148V
  • Jan 13, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 15, 2025
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
Progress Thread The Mach Returns - Update/build thread
  • squeak93
  • Feb 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 19, 2026
squeak93
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
