  • 2005 - 2009 Specific Tech
Hurst S/T not sure how I like it..
  • Thread starter Thread starter Eric3D
  • Start date Start date Jun 17, 2008
  • 3
First Prev 2 of 3 Next Last
R
Redfire281
39
#21
  • Jun 19, 2008
  • #21
I don't want to get in the middle of a heated discussion between people defending their choices and I think we should get back on topic to help the OP make a decision. That being said, here's some exerpts of posts on another forum by George of MGW, who not only owns the company but also designed the patented MGW shifter.
Regarding the stock Ford shifter:
"the reason Ford made the throw as long as it is stock is to hide some of the notchy feel and that neutral gate "BUMP" you are referring to. when you shorten the throw you will exaggerate the notchy bump in neutral. that is why the shortest throw is not always the smoothest or the fastest throw. which is the reason i made the shifter adjustable in throw. some do not mind that notchy feel but some hate it. you will NOT get a short throw AND a silky smooth shift. it is not possible unless you make a hydraulic shifter mechanism that basically removes the feel from the tranny altogether."
Further, in regards to the "notchy" feel of shifters, George posted:
"allow me to put in a few thoughts.
1. as far as the function of a shifter you are 100 percent correct. all a shifter really is is a crude lever mechanism that allows the driver to select gears by pushing and pulling and moving left to right. no real rocket science here. that is why we find it odd that people always complain about how shifters make the tranny notchy. they do not. the tranny is already a VERY notchy setup. you just cannot feel it in the stock shifter for several reasons. one is the rubber parts of the shifter allow it to rise up and down and torque ALOT with the tranny thus taking away some of the notchy feel. the other is the fact that the stock shifter has the fulcrum or pivot point very close to the connection point of the shifter/traany linkage. this makes the shift throw up top much longer but also makes the mechanical leverage very good which also dissipates or spreads the notchy clunk over a longer travel so you do not "FEEL" it as much because it IS still there.
quick little project you guys should try when changing shifters out. once the stock shifter is removed grab the tranny linkage arm and just push and pull the arm front to back to pop it into 3rd and 4th. you will see that there is a VERY distinct notch or stop space in neutral . no matter how fast you pull or how smooth you pull you will NEVER get a 1 smooth pull from 3rd to 4th. so when you say a short shifter like the hurst is too notchy you are in fact only feeling the already exisiting notchiness in the tranny just amplifide because the hurst, to its credit, is one of the shortest throw shifters on the market. hurst offers very tall long handles for the driver to compensate for this and because alot of people prefer that tall look. if their shifter was the same throw as the triax and the pro5.0 which are about 3/4" longer then it would be too long of throw by the time you get the tall handle on there.
so in a nutshell the shifter issue is as follows...
stock - best feel for smoothness and hiding the "notchy" feel. bad feel for rubbery shifts, long throw and sloppiness in the shifter.
medium throw reduction (15-30 % reduction)- best for moderate reduction in throw and only increases notchy feel a minimal amount. good for the daily driver but not really the best for drag racing or power shifting.
ultra short throw ( 35-50 % reduction)- very tight shifts and fast gear changes but also much harder to shift due to decreased mech. leverage. also the notch in the tranny gates is amplifide greatly so the shifter feels notchy. of note is that most tranny forks are bent with VERY short throw shifters because the effort to pull is so great that the driver becomes used to pulling the hell out of the shifter.
beyond 50 percent is just not practical as the amount of force to put in gear will not help daily driving or speed shifting."
I believe the Hurst shifter has a 40% throw reduction. George also posted this regarding the MGW shifter (of course there is no rebuttal by competitors):
"the MGW shifter will allow the customer to VARY the shift throw from about 15 percent shorter than stock to almost 50 percent reduction. therefore those that want a tighter feeling shifter but are not crazy about having the shortest throw on the market can set the shifter to the longer throw range . those that do not mind or actually prefer the notchy feel and want the absolute shortest throw can set the shifter to the shorter range. simple as that
also you mentioned the slop in gear. this is due to the fact that the stock shifter no longer has a centering spring in it at all. the older mustangs had a spring mechanism in BOTH the tranny AND the shifter. the new s197 cars only have a spring load in the tranny . so you have nothing to take away the slop in the shifter when the car is in gear since there is some play in the tranny linkage arm. the only companies i know of right now that have centering springs are steeda and pro5.0. the hurst does not and neither does the b&m( to the best of my knowledge). the cons of having these centering springs is that they do not allow the center shaft to rotate freely with the gear linkage arm and are a bit harder to shift..."
To the OP - on a personal note, I like the look of the Hurst shifter and the 40% throw reduction is what I'm looking for, so the Hurst is my choice irrespective of the adjustability of the MGW (which I also believe is the premier shifter of the market at its price range).
Hope this helps.
John
R
ranger04
245
#22
  • Jun 20, 2008
  • #22
You guy's would think the sun rises and sets on that stinkin MGW shifter or something. It's whats popular, so everone jumps on not to be the odd man out, it's like the latest trend or fade, ya gotta have one of these to be cool. Stamped steel or whatever, I've yet to destroy a hurst shifter in 30 years, may have striped a few knobs on hard shifts. My take on MGW is that it's ugly and expensive. I'm not paying that kind of coin for uglyness or a butter slicer. Hurst has been around before MGW was even a thought and will be around when MGW is a distant memory. The hurst is the best looking shifter on the market, the throws are short and crisp, I haven't missed a gear yet. With the new billet edition, the shifter should last as long as the car. It looks so impressive to see that hurst equiped emblem on the truck lid of an S-197. For you MGW guy's, I'm glad you love your shifters, but all of us don't want butter slicers, we want a manley shifter. Hurst was good enough for grandpa, it's good enough for me, so man up and get a hurst. I hope you guy's know I'm joking to a large extent before you get out your flame throwers. I mean I do perfere hurst and love those shifters, but whatever shifter you have is awesome if it works for you and you like it. Different strokes for different folks. The hurst MGW debate goes on about once a week on these forums, so we have loyal fans of both, it boils down to individual taste. As long as your happy with your shifter whatever it is, thats all that matters. Some even like the pro 5.0 shifters, steeda and so on, it's all good. Our common bond is the stang, not the shifter in it. However, hurst is still the best, screw the rest hee hee.
xtweakerx
411
Jupiter,FL
Jun 20, 2008
#23
  • Jun 20, 2008
  • #23
god damn i want so many parts but im out of f'n money for now..
this is a sad sad day..
i must plan a wedding and a honeymoon.. ffs...
i want a new shifter =[
NastyStang113
1,567
Florida
Jun 20, 2008
#24
  • Jun 20, 2008
  • #24
I'm not trying to be a dick but it seems like you're post kind of goes in a few different direction. In the begining it seems like you're attacking any MGW owner and accusing them of "jumping on the band wagon". I can assure you that's not the case as I tired every shifter out on the market before buying the MGW. I even own a Hurst in my 1965 Mustang 2+2. It's just no the style I wanted for a brand new car. However at the end of your post it says different strokes for different folks and I couldn't agree with you more. It seems like a lot of people in the Mustang world are not too open minded about modifications which is naive. Just like the bolt on thread, a lot of people are bashing nitrous because they are either misinformed or they just can't be a little more open minded. I said it in that thread and I'll say it again here. We all love to mod our Mustangs, that's why we're here, but no one is right or wrong about what mod they do. It's personal preference and taste. :
PS: The MGW is much better !! LOL J/K of course.
anthony05gt
1,262
Maryland
Jun 20, 2008
#25
  • Jun 20, 2008
  • #25
I'll jump on any bandwagon that gives me flawless shifts with a high hp application. My Steeda worked just fine before the 1st blower went on the car. After the procharger went on the high rpm shifts went out the door. I definitely didn't want to buy another $300 shifter. This has been the case with countless other people, many of them are people I know and do work for.
I would like nothing more than a real Hurst shifter in my car like I had on my '67 Camaro back in the day. It just ain't happening now. By the way, Hurst doesn't own Hurst anymore...it's a Mr Gasket company.
Let's all just let this subject go.
H
homebrewer
59
Richmond VA
Jun 20, 2008
#26
  • Jun 20, 2008
  • #26
Not to ruffle any feathers here, but I've been thinking of something for a while that makes sense to me, but I don't have the money to test it out right now... It seems to me from a structural/functional standpoint, that the only difference between the MGW and all others, is the the MGW is not rigidly mounted to the transmission housing. It seems to just be mounted with a floating pivot.
I believe that you could achieve the exact same function with any billet type shifter. Simply cut off the front transmission mount from the shifter, drill a hole along the longitudinal axis of the shifter, and thread it. At this point, screw in a spherical heim joint, and install. Very simple machine work, an extra $20 or so for the rod end, and all the performance benefits of the MGW, but with the added benefit of whatever look you want.
Make sense to any other engineers out there? Once I find some extra cash for a hurst billet, I'm going to give it a shot.
E
Eric3D
20
Atlanta, ga
Jun 21, 2008
#27
  • Jun 21, 2008
  • #27
Well I think I may be ordinging a MGW to give it a try. Any places to order it to save a few $ ? I see it on the MGW site but $295 plus $65 for a nice shift knob setup seems a bit steep.
I agree with so many on the classic feel and function of the Hurst I have now. My position though is that if I want that feel I will hop in my dads '68 and go for a ride. In my 06 I don't have a top loader or a 4 barrel so as much as it feels like a classic it is not.
Eric
anthony05gt
1,262
Maryland
Jun 21, 2008
#28
  • Jun 21, 2008
  • #28
The MGW is rigidly mounted to the transmission and body. At each end of the remote beam there's a solidly mounted clamping device with a layer of semi soft nylon or some sort of poly material that's between the clamping device and the beam itself. What you end up with a is a solid feel that allows some drivetrain twist under heavy torque loads associated with blower/turbo cars. Even though it feels as solid as the billet remote beam types from Pro50, Steeda and the like, you don't have the binding effect you get with a straight up solidly mounted remote beam which will not allow drivetrain twist.
Erid3D, MGW Limited is the only place you can buy from.
H
homebrewer
59
Richmond VA
Jun 21, 2008
#29
  • Jun 21, 2008
  • #29
Sorry, I didn't mean to imply that the MGW was not rigidly mounted.
All I'm proposing is replacing the "restrictive" front transmission mount, with a joint that has more degrees of freedom. Replacing the front mount with a Heim joint should allow the transmission to move, without binding the shifter arm. As the MGW appears in the pictures, the front transmission mount is allowed to spin(or at least flex significantly) around the axis of the shifter arm, whereas all the others shifters will cause a bit of bind under heavy acceleration. In theory, the Heim joint would fix that problem, and somewhat replicate the functional design of the MGW...
It's tough to decide if it will work just from the pictures, I really need to buy a shifter and get a real hands on look at it...
UrbanRedneck
173
#30
  • Jun 21, 2008
  • #30
I am a fan of the notchy, positive feel that the Hurst style shifters have. I remember playing with one in a SGT at a dealer like a year ago, and I loved it. By brother used to have a 99 GT with shifter that was REAL notchy and rough and I loved it. I guess that is my preference.
On that note, I got a Hurst shifter for my anniversary yesterday and I cannot wait to install it. Hopefully I'll get a chance to do it at work monday.
P
procharged05
Banned
Mar 8, 2008
#31
  • Jun 21, 2008
  • #31
anthony05gt said:
Well, I'm no ''youngster''.QUOTE]
Well I guess that always depends on who you are comparing to there sonny!
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jun 21, 2008
#32
  • Jun 21, 2008
  • #32
procharged05 said:
Try not to get your panties in a bind you ****ing ****...its just a shifter. I bet a young ***** like you is actually selling these POS shifters that you rave so much about...so hence your reason for hating the Husrt so much.
Get BENT you ****!
And with that....bye bye!
NastyStang113
1,567
Florida
Jun 21, 2008
#33
  • Jun 21, 2008
  • #33
Got to love the internet ...
xtweakerx
411
Jupiter,FL
Jun 22, 2008
#34
  • Jun 22, 2008
  • #34
meh, anyone want to sponsor me any aftermarket shifter so i can get rid of the stock one? PLZ!!!!
C
chubhunter
63
heartland
Jun 22, 2008
#35
  • Jun 22, 2008
  • #35
I've had both
I had a Hurst on my 05 for around a year. I recently replaced it with an MGW. I was dissapointed. After reading how great the MGW's were I was expecting something more. There is NOT much difference between the two. Yes the MGW is a little smoother. But just a little. I spent the extra 60 bucks and also ordered the white shift ball and crome shaft. Huge dissapointment. It dosen't look good and is way too exspenive. The Hurst is far, far better looking and much less expensive. I don't hate the MGW, it is a great shifter, but it is very pricey and just doesn't look very good. My advise is, save some money and buy the Hurst.
anthony05gt
1,262
Maryland
Jun 22, 2008
#36
  • Jun 22, 2008
  • #36
Then I suggest you change your sig. I call on this post. I know better.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jun 22, 2008
#37
  • Jun 22, 2008
  • #37
Anthony, you’ve already had one member lose his cool on you in this thread (forcing me to lay the smack down) because of your overstated opinion.....lets not make it a habit. You expect people to respect your opinion, so you could at least do the same. I would suggest you tread a little more lightly from here on out!
anthony05gt
1,262
Maryland
Jun 22, 2008
#38
  • Jun 22, 2008
  • #38
I tell you what. If this guy's comparison of the Hurst/MGW designs causes one person to be steered the wrong way then my ''overstated opinion'' is well worth it. I haven't typed a single personal attack by name calling, etc. If I can't state my opinion on this forum without being threatened by an overzealous moderator then maybe I don't belong here. Don't put the option for the ''BS'' sign for me to choose if you don't want me to use it. Why don't you back off?
NastyStang113
1,567
Florida
Jun 22, 2008
#39
  • Jun 22, 2008
  • #39
Something does smell fishy.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jun 22, 2008
#40
  • Jun 22, 2008
  • #40
Its got nothing to do with me being an overzealous moderator!!!
You asked....
anthony05gt said:
Show me one person that removed an MGW shifter for another brand. It ain't happening.
Someone replied with nothing more than their personal opinion and experience (which is exactly what you've been doing as well)....
...and you snapped at him because you didn't like his answer.
How can you expect people to field an opinion when if it doesn't match your own, you call them a liar? No, you haven't made any personal attacks, but you have been very condescending with your replies.....which always leads to some sort of needless drama.
Like I said...play nice. You're just going to have to accept the fact that not everyone is going to agree with you and move on.
  • 3
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
L
Car has been overheating. Not sure what is causing it. Any help would be appreciated.
  • Luckysgirl
  • Jun 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
Luckysgirl
L
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
