Hydraulic Clutch Issues
  • Thread starter Thread starter GrandeStang73
  • Start date Start date Mar 14, 2012
GrandeStang73
93
VA
Mar 14, 2012
  • Mar 14, 2012
I finally got my car started after many headaches... now my t5 won't go into gear. I have a 3/4" wilwood master cylinder and the CNC slave cylinder set-up. I've bleed the system and i believe I am getting enough throw (just over 1 inch). My push rod adjuster nut does seem to come loose after running my car. Not enough pre-load on the throwout bearing??
65fastbackresto
1,229
AR
Mar 14, 2012
  • Mar 14, 2012
Call Bruce at Modern Driveline, he does this stuff everyday. 408-394-3944.
69Rcode_Mach1
1,473
Salt Lake City, Utah
Mar 15, 2012
  • Mar 15, 2012
The adjuster nut issue is not one I have run into. It doesn't need much preload, should just rest on the fingers of the pressure plate. It shouldn't be walking out though. I wish you the best of luck in bleeding it, if it's a pain then you are on the right track. I probably spent more time getting all the air bubbles out of that thing than building the engine and swapping it in there. Personally not a fan of the hydraulic clutch at all, cable is so much easier.
GrandeStang73
93
VA
Mar 15, 2012
  • Mar 15, 2012
Thanks guys! I guess I will try and bleed the system more... Could you tell me the procedure you used?? I couldnt use a cable set-up in my car, but i did see that came out with a 73 mustang conversion set-up.
GrandeStang73
93
VA
Mar 15, 2012
  • Mar 15, 2012
I called modern driveline and all they wanted to do was try and sell me their stuff.... I bought my set-up from daze cars, 3/4" willwood master and the CNC 7/8" bore slave. The master has a 1.4" stroke and the slave has an 1 1/8" stroke, will this set-up work??
chris66dad
167
Benicia California
Mar 15, 2012
  • Mar 15, 2012
That is close to what I have. You need more preload on the clutch. I adjusted it until I could get it into 1st gear with out any grinding.
I used this from Harbor freight to bleed my system and it did it the first time.
http://www.harborfreight.com/brake-bleeder-and-vacuum-pump-kit-92474.html
65fastbackresto
1,229
AR
Mar 15, 2012
  • Mar 15, 2012
That surprises me outta Bruce, he must have been in a bad mood or something, the guy is pretty cool 99% of the time.
GrandeStang73
93
VA
Mar 16, 2012
  • Mar 16, 2012
Thanks chris, I did put the nut on until there was no play in the clutch fork and then a turn or two. How much pre-load is required?
jcode68
892
Massachussetts
Mar 16, 2012
  • Mar 16, 2012
Do a forum search on bleeding hydraulic clutch. There are a bunch of threads, some of them mine. If I recall, the amount of travel should be in the range of 1 5/8" or so. Its been about 5 years since I did mine, but I believe the key to bleeding was in the slave cylinder. You need to pull the piston almost to the end of the cylinder and then gravity bleed it a bit before doing the clutch pedal/bleeder screw dance. I will say that once I got it bled, it works perfectly and some 5 years later I haven't had to go back and touch it once. Super easy on the leg and feels like a modern car with the T5 combo. Good luck.
65wildstang
66
Loretto, TN
Mar 16, 2012
#10
  • Mar 16, 2012
  • #10
Had the same setup on my t5 and converted it over to the t56. It did take awhile to properly get bleed. My setup had the shaft and a locknut plus another jam nut. Once I got the preload adjusted I tightened the locknut & jamnut together and haven't had any issues. Good Luck
U
USAF46270
46
Sunny Florida
Mar 19, 2012
#11
  • Mar 19, 2012
  • #11
i was going to go with hyd, but iwent with a cable setup from modern driveline, with headers the 351c, it was a nightmare, now with the cable setup, its a piecenof cake
GrandeStang73
93
VA
Mar 22, 2012
#12
  • Mar 22, 2012
  • #12
Just got the hand vacum pump from harbor freight! I'm sure this will help in the bleeding process. How did you "pull" the cylinder out of the slave cylinder?
chris66dad
167
Benicia California
Mar 22, 2012
#13
  • Mar 22, 2012
  • #13
I connected the vacuum pump reservoir container to the slave cylinder bleed screw and then to connected the pump to the reservoir. Be sure to have someone up top filling the master cylinder reservoir because it will empty very fast. Do not let the vacuum pump container get more than 1/2 full or let fluid get into the pump.
I did not have to pull or extend the slave cylinder to get the air out of it.
GrandeStang73
93
VA
Mar 24, 2012
#14
  • Mar 24, 2012
  • #14
Thanks chris! I'll be trying out that today, I was thinking of making the slave cylinder and master cylinder a loop with the pump in line. I'll see if it is possible, that would be the best way to bleed anything im sure!
horseballz
824
Las Vegas, NV
Mar 24, 2012
#15
  • Mar 24, 2012
  • #15
If the bleeder is not directly at the top of the bore/slave cylinder, you will be lucky to EVER get all the air out, even with a pump or pressure bleeder. DAMHIKT! Basic science, air is lighter than hydraulic fluid and that one little F---ing air bubble can get trapped at the top and make the operation spongy/not enough travel (air is squishey, hydraulic fluid, not so much) and you're pooched until the air is GONE!
Just My $.02,
Gene
GrandeStang73
93
VA
Mar 25, 2012
#16
  • Mar 25, 2012
  • #16
I got it going in to gear and rolling!!! after 5 years .... Yes, the bleed screw was on the top of the slave. I bought a dollars worth of vacuum tubing and placed it over the bleed screw and ran it up to the master cylinder!! Just kept pumping up the pedal until I saw no more air bubbles. irate: Time to go pillage some Hondas!!! argh!
chris66dad
167
Benicia California
Mar 25, 2012
#17
  • Mar 25, 2012
  • #17
Awesome! Have fun eating some "rice" for lunch.
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
U
Knowledge Sought
  • USMCE3ROFP
  • Dec 6, 2025
  • Other Auto Tech
Other Auto Tech Dec 6, 2025
USMCE3ROFP
U
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
