hydraulic roller to solid roller?
79lxSBF
11
Can anyone confirm that you can use a solid roller cam in a 85 and later 302 roller block? If so does anything else need to be changed besides the cam, lifters, valve springs, and possibly distributor gear?
Before you ask why ? I want to rev past 6500 rpm's and don't mind setting valve lash. My car is carb'd.
Thanks in advance!:flag:
Definitly good pushrods, the Trick Flows are good for the money, 1 pc chrome moly. I usually run oil restrictors as well, you do not need all the oil to the top end.
What is the combo?
Thanks for the info guys. The combo is simple. Stock bottom end with forged pistons, gt-40x heads that will be cleaned up, victor jr. intake, BG holley 750, and cam(not decided, depends on what I can do to the head$) I use a T-5 and 4:10's. May go to 3:73 in preparation for a small shot of nitrous. You obviously have knowlege an experience, what is your input?
