Hydraulic Throw-Out bearing fitment issues...
ozstang65
313
Queensland, Australia
I know there's a few of you out there who are running a H.T.O.B. I have a QuarterMaster unit which I will be using, hopefully, in a few weeks time. I went to do a trial fit-up the other day and found that it wouldn't fit over the input shaft housing (Toploader). It's not far off, 30mm I/D and the housing is about 30.4 O/D so there's not much in it.
I was just wondering if anyone else has come across this issue before. The part numbers on the box check out OK for the intended application. I can machine down the housing if required, just didn't want to go to the effort if
i shouldn't have to.
Thanks
