With gas prices what they are I am looking at building a 2.3L turbo but keeping my current motor setup. Not looking for a road racer but something that is fun to drive at about 200hp.
Is this setup feasible?
Rebuild stock 2.3L motor with DIS and DP head but install ARP rod and main bolts and forged pistons.
Use SVO or Turbo Coupe fuel injectors.
Turbo spec roller cam, multi keyway cam sprocket (Not a fan of adjustable cam sprockets; havent seen one yet that doesnt slip).
Stinger Performance BAMAFUEL tuneable ECU
Stock exhaust manifold and turbo (87 turbo coupe) for now but at least 2.5" downpipe and single exhaust.
What other throttle bodies can I use? I have seen Tiny Avenger sells a adapter to use a 94-95 throttle body but Im betting that probably wont fit my intake.
I can send the head to my dad in Florida as he has a professional port and polish business and he used to run a built 2.3L Pinto.
Will I need to get a bigger Mass air sensor?
I also have access to a complete 84 turbo 2.3L with no turbo and a 87 2.3L turbo with no manifolds.
I just had the TO3 turbo into shop for inspection and shop wants $600+ dollars to rebuild it. I thought that was a bit high.
Any constructive comments or suggestions would be appreciated. I have lots of experience with the old 79-81 carb turbos but this would be my first foray into EFI turbos.
Thanks!
Mark
Thanks!
Mark
