Engine I am having trouble with the engine in my 1991 Mustang.
  • Thread starter Thread starter sands9330014
  • Start date Start date Sep 28, 2024
  • Tags Tags
    idle
  • 3
First Prev 3 of 3
AeroCoupe
5,959
4,073
183
Claremore, OK
Oct 9, 2024
#41
  • Oct 9, 2024
  • #41
It’s an A9P series ECU which is for an automatic transmission. What transmission do you have in the car?
sands9330014
69
japan
Oct 9, 2024
#42
  • Oct 9, 2024
  • #42
It is an automatic car.
AeroCoupe
5,959
4,073
183
Claremore, OK
Oct 9, 2024
#43
  • Oct 9, 2024
  • #43
With everything you have done and not getting any codes for O2 sensors reading rich I just keep coming back to the ECU needing to be sent to ECU Exchange.
Reactions: 89ripper
sands9330014
69
japan
Oct 9, 2024
#44
  • Oct 9, 2024
  • #44
Does the BAP sensor have anything to do with it?
Mcmahst
5 Year Member
Jan 19, 2021
686
270
83
Laguna Woods CA, fort Mohave AZ
Oct 9, 2024
#45
  • Oct 9, 2024
  • #45
I’m just wondering, if this is a 91 Mass Air engine swapped into another vehicle, if all of the grounds are property installed? Like the one for the O2 sensor harness, the one for the ECU, etc. Missing grounds can look like ECU problems. Just a possibility.
Reactions: Noobz347
sands9330014
69
japan
Oct 9, 2024
#46
  • Oct 9, 2024
  • #46
This was a kit car but it worked properly.
Admin Dude
Jan 4, 1985
43,178
21,348
234
Box behind Walmart
Oct 9, 2024
#47
  • Oct 9, 2024
  • #47
I'm going to go with wiring and connections issues.
Something is misfed in the harness or a stray path to ground is being found like @Mcmahst suggested.
Other things that come to mind:
Why was the car parked for so long? Was it because of a malfunction?
Did you ever get to the source of that malfunction?
Bent rod generally indicates a cam/timing/valve interference problem.
Do you happen to know what maintenance was done or attempted prior to it getting parked?
At this point, I am going to recommend that you go through the, "Surging Idle Checklist".
Thread 'Help me create the "Surging Idle Checklist"'
Apr 10, 2005
Updated 05 July 2022 to add rough idle when cold and smooth idle when up to normal operating temperature. See the EGR tech information, section #15 for more help.
Many of you are familiar with the "Cranks OK, but No Start Checklist for Fuel Injected Mustangs" checklist and the No Crank Checklist. They are very effective in finding and eliminating the problems by use of a systematic process that checks and eliminates possible causes. This idle problem checklist will use the same troubleshooting strategy and methodology.
By the term surging idle, I mean an idle that...
  • jrichker
  • 1986 1993 86-93 check engine light code 67 cranks ok dump codes eec-iv mustang no start
  • Forum: Fox 5.0 Mustang Tech
Let us know what portions of these tests are bad and give a shout if there is some portion of the checklist that gives you trouble.
Mindseye007
10 years still blowing strong
5 Year Member
Oct 21, 2020
579
135
63
ontario
Apr 12, 2025
#48
  • Apr 12, 2025
  • #48
sands9330014 said:
When the engine of my car gets warm, it starts idling very poorly and the engine stops.
It won't even restart. At that time, I measured the ECT voltage and Ω. 4.8kΩ for 1.2v.  n the scanner tool, 40, 15, and 12 returned, but they disappear again.
I measured the compression again, checked the plug (black), and tried installing a different plug cord, but the symptoms are the same.
View: https://youtube.com/shorts/WeLeM2Z8VFg?feature=share
What is the timing set at? Sounds off to.me...
  • 3
First Prev 3 of 3
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sunday at 2:52 PM
JohnKay
J
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
Engine Popping noise in the intake. Frustrated still.
  • esteban31065
  • Apr 6, 2025
Fox 5.0 Mustang Tech May 23, 2025
gkomo
