- Apr 25, 2005
- 1
- 0
- 0
302ci-->306ci --->1994 5.0 - Specs Below--->
Well guys & gals, I have saved some hard earned $$$ to add some ponies under my 1994 Black GT. After 11 happy virtual stock years & planning here is the list:
302 bored .030 over (9.5:1 compression)
FRP stock crank balanced
Steeda forged pistons
Steeda #19 CAM
Edelbrock Performer Heads 2.02"
Crane 1.6 roller rockers
FRP lifters
ARP head bolts
Edelbrock Performer 5.0 RPM II intake
FRP 70mm TB
BBK CAI w/ C&L 76mm Mass air meter
K&N fenderwell
Hi Flow waterpump
Edelbrock Dual Timing chain
FRPP High flow oil pump
24lb FRP injectors w/ C&L sample tube
255 lph fuel pump
MSD 6AL Box, Master Blaster coil
FRPP Dizzy, rotor & cap
FRPP 9mm blue wires
Autolite plugs 3923s
King Cobra Clutch
Steeda quadrant cable
Motor mounts
BBK Long tubes & stage 8 locking nutz
BBK X-pipe
2 chamber Flowmasters 3" chrome tips
Aeromotive AFPR
Autometer Dash Bezel with "Z" series fuel pressure & Oil pressure
Autometer "Z" clock, "Z" volts with dash pod
3:73 Gears, bearings & speedo gear
Steeda tri-ax short throw shifter
Steeda Aluminum drive shaft
Steeda suspension pack front & rear with sub frames, lowered.
Power Slots , VGX pads
Bullitt 17s
Mac U/D pullies
recharge A/C
Griffin 3 row Aluminum radiator
Blue hose kit
Custom chip & tune
Other minor goodies (Alum pedal pads, shifter knob, new mats....)
(Vortech S1 sometime later on this year)
6 quarts 5w30W oil, filter, 2 gallons coolant, 15.4 gallons 93 octane
11.5k swap for my ignition key. Car due back 6/22.
Its mine, mine, mine all mine.
Did I forget anything? Please reply.
Sleeper...YES!
Steeda #19 CAM
FRP lifters
ARP head bolts
FRP 70mm TB
K&N fenderwell
Hi Flow waterpump
255 lph fuel pump
FRPP 9mm blue wires
King Cobra Clutch
Motor mounts
BBK X-pipe
Aeromotive AFPR
Bullitt 17s
Mac U/D pullies
recharge A/C
Blue hose kit
Custom chip & tune
Sleeper...YES!
