I broke a real lug....help
I broke a rear lug....help
I was taking off my rear tire and one of the lug nuts was harder than usual to remove, in the process the lug and lug nut completely broke off. Now I have to fix it, is there anyone who's had this happen to them? Was it an easy fix or should I take it to a shop to have fixed? TIA
You should be able to either rent a tool to push the stud out or just pound it out with a 2lb hammer. New studs are like $5 from the auto parts store, and to install a new stud just slip it through the backside of the axle face and slip a junk socket over it then you can tighten a lug nut with a wrench to pull the stud through the axle face. Be sure you have something between the axle face and the lug nut though (such as an old socket or some kind of round spacer), otherwise you risk f'ing up the threads.
Dumb question, do I need to take off the rear brake and disk?
For safety's sake, I'd replace them all on that axle. If one was compromised, the others may be, as well. Studs are cheap, cars are not.
I disagree, if his lug nut was seized to the stud and it was simply a matter of over wrenching on it, the integrity of the remaining studs is likely fine. I guess we probably don't know enough about the rest of the studs to say for sure, but its a good question no less.
Just go to your local parts store and they'll get what you need. I don't remember the bolt size off hand, but they can look it up in their computer :nice:
Edit: looks like they are 1/2" - 20 thread
lol A tech at the tire shop destroyed mine when he was taking my wheel off. Then when he went to replace it, they had rounded out the hole in the hub. So he then had to replace the entire hub.
It's not hard to replace though.
