I effed with some ABS wiring and now my anti-lock brake light is on.....help!
Yesterday I swapped in a new A/C condensor (thanks to mytight95) and noticed some frayed/bare wires. about 1.5 inches from the ABS connector, about 8 of the wires were exposed to the wire. I figured it would be ghetto to just wrap electrical tape around then so I cut and soldered them all back together and covered them in shrink wrap. Now my antilock brake light is on. Did the solder mess up the resistance of the wires? What was I supposed to do? What do I do to fix them.
thread revival
My ABS light won't turn off!!
The driver side radiator tank was leaking @ the seam before I swapped it out recently, is there ABS stuff in that area that could have been damaged & where should I look?? I will check the fuses when I get home to see if that's the issue.
thanks in advance!
