I get my 2 1/2 high flow catted x-pipe tomorrow and it works without the air pump so i will be deleting it as well. Can you guys tell me what part number belt to use after i delete the air pump?
what i did was disconnect everything and left it on there... not the best way to do it, but i didn't have to mess w/ anything else... hell, i don't even think i've turned it off w/ my tweecer.
my plan is to get the delete kit--may be something for you to consider. if not, you can always measure for a new belt size w/ a tape measure, then subract an inch or so considering you'll need some tension.
I've had the best luck with a 90" gatorback
So 90" and got any pics of the way you roughted the belt?
I am not going to have any problems with the way it runs if I just remove it without a tweecer right?
I am wary of dicsonecting it if you have cats...
I ran my stock cats without the air injection tube for a couple days and after a good run (40 minutes or so) the cats would "clog" up and the car would run like absolute crap... after sitting for a few hours it would be OK for a while...
What size belt did you end up with?
