I got a Huge Problem
Aug 12, 2003
141
I have a 347 with 185 AFR heads stud mount, I don't know the size of the cam , well here is the problem the rocker arms keep coming lose and falling off,I know how to adjust the valves but after the adjustment you can hear the valvetrain, Im using stock size hardend pushrods, I have bent both pushrods in the #1 cylinder, Well do I need longer pushrods, well the reason I don't know what the cam is that I had friend build the engine and he said he had a Nitrous/ Supercharged cam that a friend was selling, so he put it in. i CAN'T GET REACH THE LOOSER KNOW, Help!!!!
Do you know if you have enough piston to valve clearance?
Also, do you know how the cam was installed? Straight up... degree'd?
I have not worked with roller rockers yet, so I'm not sure how to lock them in place.
What ratio rockers are they?
