  • 1994 - 1995 Specific Tech
I hate MA
  • Thread starter Thread starter KarmaKid
  • Start date Start date Jun 9, 2005
K
KarmaKid
84
Western MA
Jun 9, 2005
  • Jun 9, 2005
Grrrrrrr.
Failed my inspection yesterday because of my off road pipe, which I expected, but I still hate how strict MA is with thier dmv laws.
Anways, I removed the x-pipe. In doing so I broke one of the bolt's that attaches the header to the x-pipe. I tried using some channel locks a.k.a. vice grips, just to get through inspection, but not enough room. I have a nice exhaust leak now and looking for some ideas on how to fix without buying new headers. Tomm. I am going to try and find a c clamp and try clamp the couplers together.
BTW they are stock headers.
Any suggestions?
Grn92LX
Fidanza Man!
6,819
64
129
New York
Jun 10, 2005
  • Jun 10, 2005
Can't find someone to give you an under the table inspection?
Fwiw, my friend's 90GT passes with flying colors with Longtube headers and an offroad h pipe. I had an inspector 2 years ago put his personal 89LX on the emissions machine and it had an offroad h pipe. Passed just fine and got me my sticker
94-302-vert
1,947
NE CT
Jun 10, 2005
  • Jun 10, 2005
For that bolt what I had done was drill out the studs and use regular bolts... So far it has worked fine but it is a PITA to get evertyhin started...
Black95GTS
1,644
Marlborough, MA
Jun 10, 2005
  • Jun 10, 2005
I did the same thing when I switched to mine, snapped TWO of those bolts clean off. I also had to drill them out. It sucks but there's nothing like working with metal bolts that have been heat cycled thousands of times over a 10 year span...
Methodical
1,192
11
59
Clinton, MD
Jun 10, 2005
  • Jun 10, 2005
Well, here in Maryland the inspection stations look under the car with a mirror to make sure you have the cats on or its a $10K fine. My suggestion would be to remove the header from the car and try to get it out - hell you already have the exhaust removed. And the stock headers are easy to remove. If you can't remove the bolt, take it to a machine shop, they can do it in a matter of minutes for practically little of nothing and have them run a tap to cleanup the threads. It's more work but probably take the same amount of time as drilling it from underneath the car. Also, very important, whenever you remove any exhaust bolts or any bolts from under the car, Always and I mean Always put some "AnitSeize" on the threads that way the bolts are easy to remove in the future. No more breaking bolts. Believe me. Good luck Peace.
94-302-vert
1,947
NE CT
Jun 10, 2005
  • Jun 10, 2005
Methodical has a really good point.. it took me days to get all 4 drilled out once i snapped them off!!!
Looking back I think he is right!!!
Chris
deadlast
495
Belmont, MA
Jun 10, 2005
  • Jun 10, 2005
i just got my offroad pipe put in after i stripped a bolt, and im in MA too. havent figured out yet how im going to pass inspection, i really dont want to swap the pipe on and off every inspection, and its going to be hard to get a sticker under the table. MA sucks
dstanggt50
1,316
Woodinville, WA
Jun 10, 2005
  • Jun 10, 2005
10k fine????
isn't that worse than cali??
WhiteStallionGT
465
Northern VA / VT
Jun 10, 2005
  • Jun 10, 2005
Damn sorry to hear that man. I passed my inspections with my o/r H because my friend owns a gas station. I would have failed also if I took it somewhere else.
Y
yellow1995Cobra
2,959
Massachusetts
Jun 10, 2005
#10
  • Jun 10, 2005
  • #10
My old car with the 418W passed MA emmissions and inspection no problem I had no cats, no hood, no smog, no nothing haha
Its just one of those things where you gotta know somebody...
Ozz
I think I have a problem here.
3,514
66
109
Canton, MI
Jun 10, 2005
#11
  • Jun 10, 2005
  • #11
You had no cats, what do you expect.
Here's what I failed for in the past:
year 1: no washer fluid, couldn't prove my squirters worked = safety hazard.
year 2: exhaust is louder than stock. I had stock headers and H pipe w/all cats, and only an aftermarket catback. Also because of the blue tinted headlights I had, which was hardly noticable to begin with.
year 3: no front plate attached
K
KarmaKid
84
Western MA
Jun 23, 2005
#12
  • Jun 23, 2005
  • #12
I know I had no cat's. But MA does emissions every other year right now because the entire inspection process take so long. So I figured I could getaway with it, No biggie. I took the header off and brought to a shop. They used a torch to heat the flange and removed the stud. Bought a new stud at the hardware store, grade 8, putting everything back together today.
A nieghbor of mine a few houses down has an 03 Cobra. Talked to him and he said he he's got the "hook up" for my inspection next year. Putting X-Pipe back on too.
DJHA90
581
Texas
Jun 23, 2005
#13
  • Jun 23, 2005
  • #13
I failed safety in Texas because I had a little water in my headlight...
Ozz
3,514
66
109
Canton, MI
Jun 23, 2005
#14
  • Jun 23, 2005
  • #14
WOW ya got me there! That sucks!
9
95yellowGTS
41
Pope AFB, NC
Jun 23, 2005
#15
  • Jun 23, 2005
  • #15
gotta love Indiana....no emissions where I'm at! it's nice being able to drive crap around that pollutes so much ie: my old bronco. 351M, performer intake, 650 holley, longtubes, running pig rich ahhh.....those were the days. now it's just the stang, stock, except no cats and an american thunder cat back. the point is, move to a state with no inspections and all your problems are solved! ok i need to stop drinkin the whiskey and get to bed haha
A
Fox Planning on building my foxbody and was wondering if I can get any tips or anything to watch out for!
  • Angelq1028
  • Oct 31, 2024
  • 2 3 4
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 29, 2025
Robman8028
R
On3 Performance Install Tips
  • flstang65
  • Dec 15, 2019
12K
1996 - 2004 SN95 Mustang -General/Talk- Mar 17, 2023
atomicfox236
A
Timing Cover/harmonic Balancer Removal And Replacement
  • jrichker
  • May 28, 2017
16K
Fox 5.0 Mustang Tech Jul 6, 2024
Progress Thread Matt's 93 Lx - Running Issues
  • mattyv
  • May 10, 2016
  • 4 5 6
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 4, 2018
mattyv
T
600+hp Gear Ratio And Rpm Help
  • TomasV
  • Apr 10, 2016
4K
2005 - 2014 S-197 Mustang -General/Talk- Apr 11, 2016
TomasV
T
