blackfang
You don't neeed heads for a PI swap. The cams and intake is what nets most of the hp. The heads will get you 5-10rwhp due to the increase in compression. The NPI heads can be used which have a better quench pad and burn faster than the PI heads. Granted the exhaust side of it can use some work. The money you use for heads can be used to port the NPI's and you can still use the PI cams. Plus this will make more hp than if you went with PI heads anyways.
Some people have had great success with NPI heads. Johnny L is running 12.3's with his NPI headed motor in a T bird.
does that make me a bad person?
