i have a coolant leak. help
Critter_04
49
Ohio
I havea coolant leak i think, well there is no puddel of it on the ground but i am loosing coolant i have changed both heater core hoses and have a new radiator where else could i be loosing it, do fox bodies have proclem in a ceartain area?
Daggar said:
Head gasket perhaps? Radiator cap could be old. Throttle body spacer gasket leak. Does the exhaust smell like antifreeze?
I'm with Daggar on this one. Even if there is no water in the oil, there could still be a head gasket or intake gasket leak.
A good engine cleaning with degreaser and drive it until it is dry. Then park the car over some cardboard to see if there are any leaks.
ya, i was going to ask if you saw any under the car where it was parked. when i got my 224k mile notch, it had a leak behind the timing cover, in a heater bypass hose, both heater core hoses were punctured, and the pipe that runs from the heater core hoses to the front of the block was rusted through. I mean, the possibilites are endless, and its impossible for a internet mechanic to figure it out.
