ron67fb
Get an old working spark plug and plug it into one of the wires, then lay the body of the plug onto a grounded surface like the block but away from fuel. You should see a bright yellow spark while cranking. A blue spark is a spark but not a strong one. If you wired your coil backwards you will get the dim blue spark.
If there is no spark, then you can start testing components. Your coil is new, so we can probably skip that. Next, with ignition on, check that the coil is getting power at the + terminal and chassis ground, NOT + and - at the coil.
If you want to check the coil, disconnect it and connect the tester leads to the terminals, and set it to ohms. There should be some resistance but you won't know the right value unless you have the specs for it, or an identical coil to compare it to. Zero resistance means it's shorted internally, and infinity (open) shows an internal break.
As for the aftermarket module, unless you have a service manual for it, there usually no way to test it. Being the most expensive part, check that last.
