I need a headliner board
KENS89LX
302
Cross lanes Wv
My 89 needs a new headliner and I have searched the internet for replacement, and all that I found was a complete headliner with cloth . I would like to have vinyl back in it but can't find it. Has anyone redone one theirselves? I found very similar backing board a the warehouse I work at and going to try that...just need to find the vinyl!
Is the actual board damaged? If it is just the material and foam that are worn, then you can reuse the original backing board. Remove all the headliner and foam material you can by hand, then go back over what's left of the foam with a stiff bristled brush. Actual headliner material come with a foam backing, but if you want you can use a thin layer of foam, and some light weight vinyl, to get a nice finish.
Remove complete headliner from your stang. Once the board is free of old foam residue, lay the foam (very thin) over the headliner board. Fold half of the material back, and spray the face of the headliner board, as well as the mating surface of the foam. Lay out the foam in a smooth fashion. The you can fold back the other half of the unglued area, and repeat the same step. Applying the light weight vinyl of your choice, will be applied in the same fashion as the foam was, one half at a time. This reduces your chance of wrinkles in the final product.
After the material is in place, you can use a razor blade to trim excess material from the edges of the board, as well as cut the opening for the dome lights. You can trim, and glue these openings for a nice factory style finish. Reinstall in vehicle, and feel proud of your own work.
update: I got some cardboard similar to factory and had it 90% cut when the razor slipped and well lets just say I had to make a trip to Urgent Care for a couple stitches , anyway what kind of glue is good to glue the board to the foam? the glue I have for the headliner is eating into the foam. Thanks for any help!
3m adhesive spray.
also I re did a head liner on my wifes old camaro and some of the board was in rough shape, some even broken completely off. I laid some fiberglass from the back/top of it to keep it all together and it worked perfectly.
